Pertronix Install questions
georgeramos
Your car is a: 1971 124 Spider 1608
Post by georgeramos »
I finally bought the Ignitor and the Flame thrower coil from AR and started the install this morning. I cleaned and re-lubricated the advance plates/springs, removed the points and condensor and swapped out the bracket/coil. I have a couple of questions I hope someone can help with before i complete the install tomorrow. (had to cut it short today and went to look at a bunch of NOS parts i might buy...stay tuned)
Anyhow, the plate that came with the kit only seemed to fit on the dizzy in one position which is shown here...
First question - Does that look OK to have the ignitor module so far away from the distributor cam?
Second question - the old coil had a green/black HOT lead to the ballast resistor with a short red from the BR to the Pos coil. Do I simply cap off that green/black? or does it now need to go directly to the +coil?
I think that's it for now, I am very excited to be doing this upgrade...
vandor
Re: Pertronix Install questions
Post by vandor »
As it states on the invoice the clearance between the ignitor and lobes should be ~0.030", so it looks like it's too far away.
Yes, the hot wire goes to the positive of the coil.
georgeramos
So far i cant find any holes to achieve this. I will mess with it tomorrow...
Sorry Csaba, I didnt look at the invoice.
RoyBatty
Post by RoyBatty »
Remove the module and flip the mount plate over. See if that opens up more choices.
georgeramos
Thanks Roy, i'll try that.
georgeramos
Got it installed, wired, set timing and on first run still had a miss at 3500rpm. Pulled plug #1 and it's ceramic insulator was completely gone. New plugs (and wires, why not) and its running great although I must say (and Keith will agree) my car ran quite nicely with (single) point setup. No noticeable change with the Pertronix but hopefully less fiddly in the future. I am glad to have done it. :D
vandor
Post by vandor »
Glad it's running well!
81SPIDERMATT
Post by 81SPIDERMATT »
was the answer flipping the mounting plate?
georgeramos
No, it was just really paying attention to the instructions... :roll:
Im pretty certain the holes shown on the instruction sheet are the ones to follow.
dimitridodys
Your car is a: 1983 mira
Post by dimitridodys »
Did you have the problem of the Tach not working after the installation? I installed the same setup from AR in my 1974 Spider. Have not gotten the tach working since. Let me know. Thanks.
georgeramos
No. Tach works fine.
dimitridodys
What year is your car?
georgeramos
71 with 1608 and cam mounted dizzy
georgeramos
Re: Pertronix Install questionsUPDATE
I had the car out for a longer drive yesterday and it definitely runs smoother through the power range than the point system. Not sure if it feels faster, dont think so but it purrs now where it used to rattle a bit.
