2.0 with dual carbs
2.0 with dual carbs
Run. Great . When I stomp on the gas and the car runs good, then right after that it will sounds as it is missing, I do know the number 2 cylinder is not getting gas,,once the plug was dry so that. Is how I knew,bust I'm not. Positive what carbs theses are yet
This afternoon I took the set screw out of it and blew some air into the hole, then replace that screw , I turned in in a few turns and it ran good,but untill I trompton the gas. Again ,then it was missing again, so what is the
Problems. Maybe if I could understand what is going on then I could fix it,
I was thinking about getting a kit for the carbs and have them put in,I will have to take the carbs off just so I can determine what I have
Any. Ideas on why I turns good then when you beat on it then it like starving for gas
I know it. Not missing because. I have new plugs in it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: 2.0 with dual carbs
Not uncommon for these to have a bit of crud floating around that can get sucked into a jet when working hard, only to float around again after you turn it off. I had to give my IDFs a clean out the other day for this reason. I've also got 2 filters, 1 before the pump and one on the return line.
Mick.
How do you clean it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Do you think that new kits would help
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
took the carbs off/ cant even see what there are , other then a weber, but no other marking
size 120
idle jets are 50
size 120
idle jets are 50
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
http://www.carburetion.com/sitesearch.a ... arburetors
this is just what it says for a kit, how do i know what im getting?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
To know the size if it a 38mm / 40 . It should say on the butterfly's right. There is a number there
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
The jets you have are very lean for a 2.0L. Try going to 130 or 135 mains, 185 or 195 air correctors, and 57 idles, or at least 55's. This assumes you are running and F11 emulsion tube with 40 IDFs and 32mm chokes. Be sure the floats are set at 32mm open and 10mm closed, and that the carbs are balanced and synchronized. This may help:
http://fiatspider.com/f08/viewtopic.php?f=5&t=14494
From what you describe, the problem is when you are on the idle jet circuit (running normally) and given that you are running 50's, it is likely the problem is just not enough gas, or an idle jet or jets are clogged with dirt, or both. If your #2 doesn't seem to be getting gas, try cleaning that idle jet first.
When you stomp it, you move to the main/air corrector jet circuit, and there it runs fine, but I suspect you will be pleasantly surprised when you go to larger main jets and stomp it.
Are there any other performance mods on the motor?
Ok, thanks, I just ordered the correct stuff, we will see what happens after I get them
I don't have as clue if there is been a change to this engine
I ordered, main jets ( 4 ) 135 (this was 120
Idle jets. ( 4 ) 55 ( this was 50
Air corrector. ( 4 ) 195 ( this one is 210
f 11
f 11
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
What is the f 11 emision tube,? Is that what holds the air corrector and main jet
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
That's right. The number will be stamped at the bottom of the tube.
it is f 11
Parts on it way. Thanks for helping
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
carbs are off and i was putting in the upper dash, so i had the key on just checking for power.
well before that i was using gas outside by the door to get the carbs clean,that and brake fluid.
anyways so i smelled gas in the garage, thinking it was from the cleaning i did, well it dawn on me that i can hear the pump running, omg the floor of the garage was full of gas, i bet there was 2 gals . well i knew anything could set that off so i carefully got out of the car and thinking i need to shut the power off in the garage, well i did ,thank god for that / got it cleaned up, cant even imagine what would have happen with one spark, i mean i do know, it waould have been flames of hell and prolly exploded that fiat ,next to it was the other one pay attention james THINK THINK
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Patron 2019
- Your car is a: 1979 124Spider
That should have read God, not god.
