1975 spider stalls out
my 75 spider has been running great, last week end out for a ride and it stalled out while driving. i pull over let it sit and restart . i get to second gear and it stalls out again, after several times i figure maybe water in the line. so i put in some dry gas and it continues to stall out even in nuetral and revving the motor it will stall out. I heard points could be a problem. i had it tuned last yr any suggestions
Re: 1975 spider stalls out
First things first. Check the fuel filter. You are not getting gas.
The odds of a fuel filter plugging that fast are slim to none.
But you do need to check some basics. WHen car stalls does it stay dead?? How do you get it re-started??
If it stays dead for a while, check spark, use some old plug, pull plug wire, stick in old plug, lay on head, crank, should see spark.
IF it stays dead, remove air filter and pump throttle, should see fuel pissing into carb from accel pump.
Keith
Keith
thanks but im getting fuel,Exit98 wrote:First things first. Check the fuel filter. You are not getting gas.
Hi, fuel filter is good , whenthe car stalls out , i can restart put it in gear and when i get to second or around 20 25 mph it stalls out , and i start the process again thanks bobmajicwrench wrote:The odds of a fuel filter plugging that fast are slim to none.
Keith
carb bowl may not be filling quickly enough to replace used fuel, do to partial clog or gunk with float mechanism.
i checked ands cleaned all inline filters , and the fuel pump is wrking , im gettig spark because the car will run for a period of time and then sputters and stalls out, i can restart but again it will stall out. not sure what could still be my problemExit98 wrote:First things first. Check the fuel filter. You are not getting gas.
- RoyBatty
Does your car have the dual points distributor?
Possibly when the ignition is switched from the startup points to the running points, the running points or condensor are bad.
When the car dies it is losing either fuel or spark. Which is it??
When it is sitting there dead, does it spark?? Does it have fuel in the carb??
Does it stall just sitting still?? If so, as it starts to fail, piss some carb cleaner into carb. (safety glasses) does carb cleaner help??If so, it is running out of fuel.
Hi Roy the 1975 124 spider has dual point distributor . you could be on to something because in the idle position the car runs great its when it gets hot and running it stalls out . I will check out the points thanks
- DaveT
- Your car is a: 1978 Spider
I had the same issue with my '78 with dual points. I switched to single points and that worked for a while and then they were regularly going out of gap. Last year I switched to Pertronix and have never had an issue since.
Dave T
Warwick, RI
'78 Black Spider
Warwick, RI
'78 Black Spider
