Does anybody know the approximate torque for the pinion nut?
Nick
Pinion Nut
- Your car is a: 1979 Fiat 2000
- V12StealthHunter
- Your car is a: 1971 Fiat 124 Spider
Re: Pinion Nut
The correct preload typically happens between 108 to 166ft.lbs according to the Haynes manual
1971 Fiat 124 Sport Spider
Re: Pinion Nut
Thanks for the information.
- engineerted
- Your car is a: 1974 124 spider
Re: Pinion Nut
It is not that simple, It depends if you have installed a new crush sleeve or just retorquing after a seal change.
Ted
Re: Pinion Nut
Installed a new crush sleeve and seal.
