springs
juvius
Your car is a: 79 spider
springs
Post by juvius »
i messed up and mixed up all my springs... I plan on using the early springs i have since they sit lower than the later springs... is there a way to tell the difference by looking?
brad131a4
Re: springs
Post by brad131a4 »
Yup the older ones will be shorter than the newer ones. :D
juvius
Re: springs
Post by juvius »
great. thanks....
juvius
Re: springs
Post by juvius »
are you sure they are shorter? because i know two of these sets are early. one from a 70 and one from a 71. when i compared them all today, all the rears were the same height and all the fronts were the same height.... i haven't gotten rid of any of my springs, so now i'm really confused. so now i have 5 sets of springs and i don't know what's what.... it's a lot of work to install them all to see the ride height...
bradartigue
Re: springs
Post by bradartigue »
The older springs don't weigh as much, they compress more, and the car sits lower upon them.
70 and 71 (and everything prior to 74) would have the "early" springs and everything after 75 would progressively get taller. I think 75-78 weren't as high as 79-85. 79/80 springs with the 13" wheels and modern tires (e.g. lower profile than OEM) look kinda funny.
azruss
Re: springs
Post by azruss »
your 70 and 71 should be the same
juvius
Re: springs
Post by juvius »
azruss wrote:your 70 and 71 should be the same
I expected to find two sets shorter out of the 5. But they're all the same length
azruss
Re: springs
Post by azruss »
you may want to "mic" the diameter of the metal to see if there is a difference there. As I recall the fronts are the same length, but the backs are different. The only way they can make a lighter spring with the same length and number of coils is to use a smaller gage rod.
juvius
Re: springs
Post by juvius »
i will give that a try.... thanks...
