Trans oil
paintdudeluke
Trans oil
Post by paintdudeluke »
The gear lube indicated is 80-90 (not EP) which would be GL1. I used full synthetic 75-90 (valvoline synpower). I'm assuming that any modern synthetic oil is far superior to anything available back then. Any feedback? The EP (extreme pressure) component back then was containing corrosive ingredients to brass and copper components. I imagine there's nothing caustic in modern synthetic. There isn't even a GL1 on the shelf, everything says "exceeds GL5" or something like that.
What do you guys fill your 5sp trans with?
AriK
Re: Trans oil
Post by AriK »
5w30 motor oil
kilrwail
Re: Trans oil
Post by kilrwail »
Pennzoil Synchromesh. And you can get GL-1 from NAPA, among others. The modern synthetics are not suitable, as far as I know.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
focodave
Re: Trans oil
Post by focodave »
http://www.napaonline.com/Catalog/Catal ... 0434862994
Went to my local NAPA store.
They had 5 1-gallon jugs on the shelf.
I didn't even have to ask one of the incompetent 20-somethings working there, if they had it.
1970 MGB GT (my other hobby)
AriK
Re: Trans oil
Post by AriK »
Come to think of it believe i use just straight 30 (i know im gonna hear about this on this forum :wink: )
4uall
Re: Trans oil
Post by 4uall »
carl
Re: Trans oil
Post by carl »
A question like this on Mirafiori would cause a firestorm of argument. Anyway, I regularly use Redline MtL to no ill effect and you don't have to wait for it to warm up in cold weather as it has the consistency of ATF. The only problem I'm aware of is if you have questionable seals the stuff may leak out. The Haynes manual recommends 20/50 Castrol GTX which I have also used.
carl
4uall
Re: Trans oil
Post by 4uall »
WHY CAN'T WE ALL JUST GET ALONG :mrgreen:
