back seat replacement
Anything goes (within forum guidelines of course)
fiat218
Post by fiat218 »
how does the back of the rear seat ,sits in its place if the tabs are broke off?
bottom seat first then the back?
what are the tabs on the bottom of the back cushion for ?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
SunnySideUp
Your car is a: SOLD
Re: back seat replacement
Post by SunnySideUp »
Remove bottom cushion first - it should pop off with a vertical tug from the front. Remove the wide band above the rear vertical seat back that is just below the rear plastic window. From there you will see tabs and screws that hold the seat back in place.
But why replace the rear seats with "seats?". Why not replace the stock set up with a true parcel shelf? Many have custom fabbed such a set up and Allison's Automotive even has ready-mades pieces available. You would get a more practical and sensible use of the space.
SunnySideUp
fiat218
Post by fiat218 »
Got,it thanks, I just put it back because I want to get rid of this car
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
