The rebuild/ refresh looks great. Have to drive on clean roads only now eh...
I have an open question regarding the tightening the suspension bolts.
As mentioned, you are supposed to load the car before tightening, however I used a floor jack under the A-arm and jacked up until the car started to move to simulate the loading from above. Will this, or is this a satisfactory method compared to installing a couple of people and corresponding refreshments while you are mucking about tightening the bolts?
Chris
Front End Rebuild - Almost done... this time.
Re: Front End Rebuild - Almost done... this time.
I think jacking it up just puts the weight of the car itself on the suspension. They want the added passenger loading in there too. I got 2 adults to sit in the front seats, while having the jack points under the A-arms, and that seems to have done the trick.
Pete
Pete
