So all, is it better to keep posts/questions for the same car in one thread or start a new thread for new questions? Since it's a restoration project I thought it'd be best to keep it all together? Preferences moderators/readers?
I have an issue with the fuel pump - when the battery is hooked up you hear it running, even with the ignition 'off'. The ignition wiring itself seems intact except for the wire noted in the pic below which is twisted together, and the larger green wire which is cut. Haven't traced these to the wiring diagram yet.
Oh yes, and the ignition will not shut the car off when running...I assume that's related and may indicate a bad ignition?
I did notice that there is only one wire going to the fuel pump but the wiring diagram shows 2, the power and a ground, but it appears I have no ground. I'll pull the pump off today and see if somethings been cut off but if not any other ideas? Anyone else with 1 wire to the fuel pump?
Thanks all for any ideas!
