Someone needs to adopt this...
http://greenville.craigslist.org/cto/4336238216.html
First of all, it's one of my favorite Spider colors (same as mine...), and if the 11k is true, it's one hell of a deal.
If I had the cash, I'd be on the way to SC to pick it up, now.
- johndemar
Re: Someone needs to adopt this...
My guess is that the odometer has rolled once already.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
It's an 81, so it should be a 6-digit odometer. However, as we all know, it's a Fiat. What should be and what actually happens are two different things, especially with our cars.johndemar wrote:My guess is that the odometer has rolled once already.
"It's an 81, so it should be a 6-digit odometer."
I had two 1981 Spiders and both had a 5 digit odometer.
The steering wheel shows that the odometer turned over already and the car itself does not look special at all.
Also, how long has the car been siting and does it even run?
car shows signs of a repaint. looks like rust along the drivers door and neighboring panels. good little dent in the trunk lid. Fronts seats look great. wonder if the plenum was pulled to shoot ether in the motor. Engine compartment looks complete and original.
Odd.. Mine is an 81, and it has a 6-digit. Also, how does the steering wheel indicate the odometer has rolled over? It's a bit out of the way for me to go look at, but the 11k mileage did make me do a double-take.Tobi wrote:"It's an 81, so it should be a 6-digit odometer."
- fiasco
The wear on the steering wheel (see it on the spokes where they connect to the grip), as well as the wear you can see on the center console certainly indicates more than 11,000 miles of use.darksider415 wrote: Also, how does the steering wheel indicate the odometer has rolled over?
-- se
Steve Eubanks
Can I remind you that it not new. wear and tear
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
D'oh... Blame the fancy 1920x1080 display on my 12" laptop. Makes it really, really hard to pick out the little details in small images. Doubly so when I've been sacrificing sleep to work on the Fiat.fiasco wrote:The wear on the steering wheel (see it on the spokes where they connect to the grip), as well as the wear you can see on the center console certainly indicates more than 11,000 miles of use.darksider415 wrote: Also, how does the steering wheel indicate the odometer has rolled over?
-- se
- Your car is a: 1982 Spider
I agree, not a low mileage car. The reflection on the driver's side of the car is worrisome (bodywork). The passenger side reflection is more consistent with a normal reflection. $3200 is not a bad asking price if rust is truly minimal.
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
A couple of the hose clamps do not look stock
Will
P.s. This is the same color as my new one.
Will
Right off the bat, engine is way to grimy to be 11,000 miles. High mileage car, easily.
I called Chris on the car. Does not run, but ran while parked.
Sounds like some rust, but minor.
Stored since 2001.
$2500 will be all it takes to adopt.
Will
Stored since 2001.
Will
I know cars are harder to come by back east. But here in so Cal thats a 500 car.
i figured 1700spiderrey wrote:I know cars are harder to come by back east. But here in so Cal thats a 500 car.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
