my turn for:what have i started? CS2 2000 restoration
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Re: my turn for:what have i started? CS2 restoration
Post by wachuko »
Great build! Thank you for sharing the process!!
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
PininF
Post by PininF »
Great Job !!!
Will you replace the licence plate lights with originals ? , I have just replaced my bumpers and still need to remove the old licence lights… have found the light fittings that insert into the ends of the bumpers at Spider Point… Just to complete the look.
Enjoying your progress :D
Cheers
John
cos
Your car is a: 1978 cs2 spider
Post by cos »
thank you both. Regarding the licence plate lights, not sure which way to go really. I should have planned this better, and filled in the holes on the rear panel and used the the lights that fit on the rear bumper. Got to put some thought into this.....
Love to see your conversion.
PininF
Post by PininF »
Cheers will keep you in the loop…
Will be installing mine in January when I'm on short leave , got the same problem but will just use hole infills until my beater can fix it up… also contemplating early turn signals but not sure if the cut out holes are bigger, if so I won't go there…
Cheers
John
cos
Post by cos »
yeah, the holes on the early models were smaller.
fit of the bumpers on your car looks good!
cos
Post by cos »
winsscreen panel now painted and fitted.
Ptoneill
Post by Ptoneill »
I have heard that the old style bumper license plate lights are not fitting correctly on the replica stainless steel bumpers. Has anyone made this work? I have the stainless bumpers and I would like to get Spider Points plate lights but I would like the opinion of someone who has done this...of course photos are always good!
Love your car!!
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
cos
Post by cos »
thank you!
Haven't got that far yet (regarding lights), but i'll keep you posted....
azruss
Post by azruss »
The OEM plate lights do not fit the Harrington SS bumpers. I fabricated a fit using dome style lights for pick up truck bumpers. I posted pictures on an earlier thread. "License Plate Light Mod" posted March 30.
Ptoneill
Post by Ptoneill »
azruss wrote:The OEM plate lights do not fit the Harrington SS bumpers. I fabricated a fit using dome style lights for pick up truck bumpers. I posted pictures on an earlier thread. "License Plate Light Mod" posted March 30.
Thank you very much for the info.
Merry Christmas!
Stay Safe,
Pat
79spider
ptoneill@msn.com
cos
Post by cos »
weather in UK has not been on my side this winter, it's non stop rain all the time, so progress on my resto is on the slow side, so i got on with cleaning the jack instead!
Mind you this weekend the sun came out for a bit so the rear brake pipes, hand brake and calipers are now on the car....
beautiful work!
cos
Post by cos »
thank you. Enjoying it!
fiat218
Post by fiat218 »
what on your spring on the back?
I would like to know , how do u know we're all the stuff under the dash goes, and the wiring?
I realize there are wire diagrams but still
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
cos
Post by cos »
fiat218 wrote:what on your spring on the back?
hi, the spring came with that plastic netting, which i believe acts as an anti squeak. Regarding the wiring and the rest of the build, i simply took hundreds of photos, and on every connector and junction pair i put masking tape and wrote a note or a matching number. Time will tell if any of that will be of help!
