Possible oil starvation- engine rebuild?
- Your car is a: 1975 Spider
Re: Possible oil starvation- engine rebuild?
rock it backwards too, if it still doesnt free up, the problem is more serious than a out of time aux shaft
son has 78 spider
son has 78 spider
Is this an issue on 1980 FI models?vandor wrote:A lot more likely that the timing belt jumped a cog and the rod hit the fuel pump lobe at the end of the auxiliary shaft. If that is the case all you need to do is get a new timing belt (and possibly a tensioner, since you are already there...).
the aux shaft hitting a connecting rod can happen on all 2.0l engines. however it is not common for them to jump time. once in time the aux shaft will not hit.
son has 78 spider
son has 78 spider
what was the condition when it "seized", was he driving it down the road? did he pull up to a light and it just shut off? was it making any noise prior to it shutting off" was it idling? was it full throttle and started to "tighten up"? all of those answers can help better diagnose. but bottom line if it wont move in either direction, there is a major problem
son has 78 spider
son has 78 spider
It started to tighten up and loose power, and then was knocking , so he pulled over and it died.BEEK wrote:what was the condition when it "seized", was he driving it down the road? did he pull up to a light and it just shut off? was it making any noise prior to it shutting off" was it idling? was it full throttle and started to "tighten up"? all of those answers can help better diagnose. but bottom line if it wont move in either direction, there is a major problem
- focodave
BNelsonAz wrote:It started to tighten up and loose power, and then was makinga knocking noise, so he pulled over and it died.BEEK wrote:what was the condition when it "seized", was he driving it down the road? did he pull up to a light and it just shut off? was it making any noise prior to it shutting off" was it idling? was it full throttle and started to "tighten up"? all of those answers can help better diagnose. but bottom line if it wont move in either direction, there is a major problem
That sounds a lot like a spun bearing -- not good.
1970 MGB GT (my other hobby)
+1 on rod bearing, after hearing what happened, my guess is a broken oil pump pick up. using my over the internet powers.
son has 78 spider
son has 78 spider
and maybe broken oil pump gear, or just piece of sh*** chinese oil filter
Thanks Beek. Tried rolling it backwards last night: no joy. Next update after I get a socket on the main and see if I can move the engine at all.BEEK wrote:+1 on rod bearing, after hearing what happened, my guess is a broken oil pump pick up. using my over the internet powers.
don't bother. remove the sump
damn it, and I have a machine shop building minevandor wrote:If you do all the work yourself, you might/could do it for ~$1000.
I would not have a machine shop rebuild it. No idea why, but machine shops regularly mess up Fiat engines.
If you want to go that route take it to a good import repair shop.
An engine rebuild usually costs $2500-3500, depending on what is done and what is broken. Could be a lot more for a hi-po build.
As others said, it would need to be 2-3 quarts low for it to starve of oil. That is not what happened (unless someone filled it back up with oil
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
this first question that comes to my mind, was when this was all going down, did the kid bother to look at the oil pressure gage
Yeah I asked. That was a negative, Ghostrider.azruss wrote:this first question that comes to my mind, was when this was all going down, did the kid bother to look at the oil pressure gage
- mpollock
Times change - I have never owned a car with an oil pressure gauge. Even my '79 spider doesn't have one. I just picked up a used one from a '77 that will go into the center console.
No excuse on my 1980. Oil pressure is right in plain sight.mpollock wrote:Times change - I have never owned a car with an oil pressure gauge. Even my '79 spider doesn't have one. I just picked up a used one from a '77 that will go into the center console.
