Head-gasket tubes
sdebaker
Head-gasket tubes
Post by sdebaker »
Took the head off my 1977, 1800 Spider.
Through diagonal corners of the head gasket, there are two, brass tubes, about 1/4" long, with a flange to keep them from falling through the head gasket. My new, full-engine gasket set does not have tubes.
What is the purpose of these tubes? Should I install the old ones or leave them out? I am concerned that the flanges may interfere with the proper crush of the head gasket.
Also, One of my shop manuals says to smear grease on the head gasket before installation. I have never seen this in a shop manual for any other car on which I have worked. Is this a necessary step?
Tobi
Re: Head-gasket tubes
Post by Tobi »
I had them on my 2l and they are there to center the head on the block, mine did not have a flange though!?
I reused the old ones.
Don't use grease or anything else on the head gasket.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
those things should be steel dowels, anything else is not correct. it is possible to leave them out but you would have to make locating bolts, to keep the head gasket where it belongs when you are installing the head, then you pull the locating bolts out with a magnet thru a head bolt hole.
again, i recommend using the proper locating dowels
75 spider
son has 78 spider
My stock 81 engine, believed never torn down, appears to have brass too.
BEEK
Post by BEEK »
they may appear brass, but they are steel... use a magnet
75 spider
son has 78 spider
Will do. Maybe they are just grimed up.
Yep they are steel, just gunked up so they look like brass. Why am I not surprised that you are right, Beek? :)
