I've generally posted on here when in need of help. And the resource has been amazing. This forum has take my knowledge of this car through the roof and I wanted to say thanks.
That is all. No help needed today. Just thanks.
I'm a little giddy because I discovered a vacuum leak at the manifold which was causing my new weber to do bad things. In the past, this would have warranted a trip to the garage at considerable expense. But now, thanks in large part to this forum, I studied the situation, found a suspect leak, plugged it, and voila, I have my spider back!
New 32/36 running like a champ. Took her out on a snowy/icy day in Michigan. Got sideways a time or two. Good times.
Thank you fiatspider.com forum admins and participants for excellent stuff!
winter frolic
Re: winter frolic
You are right about this place Tim. Me too.
Winter driving would sure be fun. Crank the heater.
It's sunny and about 50 F. right now and I'd sure like to go for a spin but way too much salt down around here. Can't venture out till its all washed away.
