Dual carb on a 79
Re: Dual carb on a 79
Being ignorant, I'd say they perform the same when wide open on a single plane manifold:
32+36=68
34+34=68
32+36=68
34+34=68
- Your car is a: 1975 Spider
venturi size, and overall construction make a difference too. the 34adf directly bolts on and appears the same as stock.
the 32/36 is a very universal carb. i have played with many over the years and had better luck and more performance with a 34dmsa
son has 78 spider
son has 78 spider
Ok a plan is forming. Please tell me if I am makeing a mistake.
I have some amazon gift cards that make the 32/36 Empi Very Cheap ( and hides the bulk of the upgrade price from the wife)
http://www.amazon.com/EMPI-DFEV-CARB-ON ... 2%2F36dfev
From what I understand I will need a Linkage adapter
http://www.ebay.com/itm/WEBER-CARBURETO ... 4d086549e1
I still need to find a 1800 intake manifold. Is this a good price?
http://www.autoricambi.us/product/FU1-4 ... -Manifold/
Do I need a spacer if I switch to the 1800 Manifold?
And will this solution work with my Detent Cable needed for the automatic tranny?
Weber Direct sells a Weber 32/36 DFEV for $199. Empi is a Chinese knockoff of the Weber.
Damn, Chinese ? We'll I tell you this, my empi worked a lot better then the carb I got from weber directWYSpider wrote:Weber Direct sells a Weber 32/36 DFEV for $199. Empi is a Chinese knockoff of the Weber.
I know you are not saying anything bad of either one
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Weber Direct are also Chinese "Webers". Try to get a Weber/EMPI from one of the vendors at least they will be able to help you if you get stuck.
That's good to know. The one I purchased from them is stamped "Made in Spain", but that was back in 2010.lanciahf wrote:Weber Direct are also Chinese "Webers".
Nope, it's a personal preference thing. I'd also buy an AYA Spanish double shotgun over a Chinese version.fiat218 wrote:Damn, Chinese ? We'll I tell you this, my empi worked a lot better then the carb I got from weber direct I know you are not saying anything bad of either one
- MrJD
- Your car is a: Looking to ask questions about a 79 2.0
I have read mixed reviews on empi carbs... I wonder how much of that is weber elite-isms though. Can anyone in the know pleas speculate on my comments about the weber 32 adf?
- RoyBatty
I had the empi 32/36 from Allisons on my 75 for the last couple years before I installed the economy idf kit from Auto Ricambi.
The empi ran and worked fine. The only thing I can gripe about on the empi is the metal alloy used in the casting of the carb body.
The choke assy on mine kept coming loose and repeated retorqing of the choke mount screws failed to keep the choke assy secured. The threads cut into the carb body seemed to just gall up and never fully torque properly. I finally drilled and retapped the holes for 8/32 screws and secured the screws with blue loctite. Even when cutting the new threads, the way the tap felt as it made its way thru the metal of the carb body did not feel right.
I noticed the economy idf carbs seemed to not have this issue in the numerous times I've had them opened to ensure the float chambers were clean as I tweaked them into tune.
I have seen surprising test data that shows that some headers are not much, if any, better than stock, cast, exhaust manifolds. One example was a test done by Grassroots Motorsports magazine on BMC B-series engine. Headers produced less horsepower than a factory manifold.MrJD wrote:"...
Also, I have read that the 4-2-1 exhaust is just as good as most headers out there. I find this kinda hard to believe... anyone had both and feel like commenting? I tend to find that all cast manifolds are a bit restrictive by header standards.
Not saying this is true for the FIAT engine, but I wouldn't automatically assume the header is better, either. Does anyone have real data on the power output of different exhaust configurations?
How much different from the Holley 5200 series (other than jetting and air correctors, if any) is this carb? The Holley is a licensed Weber, which was used on gazillions (I am rounding the number) of Ford, some GM and some Chrysler products. There are probably piles of these higher than Mt. Everest in junk yards across the US. I suspect $25 would take one home.WYSpider wrote:Weber Direct sells a Weber 32/36 DFEV for $199. Empi is a Chinese knockoff of the Weber.
Regarding jets and air correctors: these Weber/Holley conversions are fairly popular on British BMC A and B-series engines MG's, Sprites, Morris Minors. However, many people find the jets and air correctors furnished in the new-carbs-conversion kits, as delivered, are not optimum, so they end up replacing these. This might be the case with the FIAT application as well.
Put a Weber decal on the Holley and the hoi polloi will be none the wiser.
Weber Directs cheap carbs are also made in China, they put Weber decals on them. I expect they're made in the same factory that makes the EMPI carbs. At least EMPI is still doing R&D on their carbs and have improved the venturi boosters for better transitions. The EMPI carbs do have a one year warranty.
As for headers, I've posted my dyno results for both my Spider and X1/9 headers, proving our improvement claims. I've challenged every other header mfg to do the same and so far no other vendors or mfgs have responded
- MrJD
And you're an EMPI believer right Mark?
- RoyBatty
Not sure of the tone you're taking here.MrJD wrote:And you're an EMPI believer right Mark?
But if you aren't already aware if it. Mark has been and is a huge help to all on this forum.
The EMPI carb I bought from him performed great with the one small issue of the choke assy.
And when I discussed this issue with him, he was willing to address the situation if I could not resolve it on my own.
