I notice two sets of carbs on AR web store,40iDF
What the difference between them? I assume wider throats?
IDF
Re: IDF
I am yes, so the lower cost is the same , just name brand differntSoFlaFiat wrote:Jim, if your are referring to the duel set up, one pair is genuine Weber, the other is the lower cost knock off. Pretty sure they are the same size carbs.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: IDF
Yes I'm aware of that, I need another set but I may go bigger, I will see what beek says when the time is right,
And umm, I'm not into trying to save gas it all about speed and power,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: IDF
Jim, I'm at the thinking stage of building another engine and it was mentioned to me that if I use the 2L engine, look for the 44 IDF's. Now I hope the engine guru's here will chime in to confirm as well.
Mark has a short video that compares the 40 and 44 idf's , both the EMPI and Weber carbs mounted on a VW motor when on a dyno.
http://www.youtube.com/watch?v=WP3fOWaaQy4
I remember seeing posts here regarding the hood height and the 2L engine with the IDF's...not sure what the outcome was as I thought the IDF's needed a healthy clearance above for air movement...again engine guru's please....
Chris
Chris
Re: IDF
I will get what best for what I'm getting done, I do have them dcnf, I think that what is is
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1975 Spider
Re: IDF
the dcnf's will work better for hood clearance. they are a shorter carb
son has 78 spider
son has 78 spider
Re: IDF
But,what better for what we are doing, just askingBEEK wrote:the dcnf's will work better for hood clearance. they are a shorter carb
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
