I have a question about the distributor on my 1982 Fiat Spider 2000. I have replaced an inoperative vacuum advance capsule on my distributor with a new module. While I had the dizzy out I decided to fit a new magnetic pickup. Can anyone tell what the 'air gap' should be between the pickup and the tip of the lobes on the ditributor shaft. There seems to be quite a wide range of adjustment available. I set it very close (1mm) and the car starts and runs beautifully but has stopped abruptly twice while running under test. I am wondering if I have set it too close and the lobes have touched the new pickup as it warms up. How wide a gap should I leave?
Grateful for any wisdom and experience on this subject.
Mike R.
1st Question from a Newbie - Ignition
Re: 1st Question from a Newbie - Ignition
about .016, nearly the same as a set of points. As close as possible without the reluctor contacting the pickup, but you have to allow for some play in the dist shaft.
Mark,
Many thanks for the prompt response I will give that a try.
Mike R.
Mike R.
Great advice, thank you, Mark - all sorted now, it was all to do with making an allowance for the free-play. I found I could simulate / 'pre-load' and get it just right.
What a difference a working vacuum advance makes too! You think your car is running fine without and wonder what it really does. With a new working vaccum pod the throttle response is noticeably sharper and a real pleasure to drive.
And I also found out that you really need BOTH a 17mm stubby AND a 17mm crows-foot to comfortably tighten the dizzy back up after removal - but you guys knew that already - right !
Thanks again for a great forum - I am sure I will be back with more questions soon.
- ga.spyder
Hey Mike glad to hear from another member of the 82 club.I recently changed my inop vac advance and it did make a noticeable improvement.I put in a new mag. p/u last year ,but didnt adjust anything. I guess it must be ok ,as I havent noticed any ill effects,but I will check it anyway.
Craig
Craig
Craig Nelson
Fling It Around Turns !
