Transmition to engine Block bolts size?
Does any body know what the size of the tranny to engine block bolts are? Pitch, length, etc.
- Curly
Re: Transmition to engine Block bolts size?
I have a feeling this is is one of the ones you need. 12mm diameter (11.9mm to be precise ) by 55mm. Not sure of the pitch but it is quite a fine thread. Head size is 18.85 across the flats (ie a 19mm spanner), and it has FIAT 80 in raised lettering on the face of the head.
Curly from Oz
Thank you for the information, it was definitely helpful.
Looie72
Looie72
