heat box attachment
fredguaz
heat box attachment
Post by fredguaz »
Hello,
Quick question. How many nuts hold the whole heater box assembly to the underside of the cowl ?? I have only 3 studs coming down from the underside of cowl and no evidence that there ever was a 4th. Seems like there should be 4 though.
Thank you,
Fred
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
divace73
Re: heat box attachment
Post by divace73 »
fredguaz wrote:Hello,
Thank you,
I've notice I have only 3 on mine as well...don't know if they changed over the years but mine is a late 79 or 80 FI model.
Cheers David
see my >>You tube channel<<
fredguaz
Post by fredguaz »
Thanks, David.
I don't feel alone. :roll:
Mine's a late 76, titled 77.
Fred
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
vandor
Post by vandor »
There should be 4, two on both sides.
papadopalas
Post by papadopalas »
Yep, Mine is missing the front passenger side bolt as well on my 79. Wonder why this one was left out. Think I'm gonna drill a hole from the bottom up and install one. Maybe then I'll figure out the hard way why it was never done. :)
fredguaz
Post by fredguaz »
Interesting. The underside of my cowl is in very good shape and there is ZERO evidence that a 4th stud was every put in. It too is the passenger side forward most. Not sure I would want to add a stud if there never was one. Must be a reason. ??
Fred
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
divace73
Post by divace73 »
fredguaz wrote:Interesting. The underside of my cowl is in very good shape and there is ZERO evidence that a 4th stud was every put in. It too is the passenger side forward most. Not sure I would want to add a stud if there never was one. Must be a reason. ??
same, zero evidence there was anything there....
Cheers David
cos
Your car is a: 1978 cs2 spider
Post by cos »
Recently fitted mine during restoration, and i also have just 3 fixings
wizard124
Post by wizard124 »
Just 3 on my '80
divace73
Post by divace73 »
so who was the Fiat worker that got lazy and forgot to put that last stud in......
Cheers David
weekend warrior
Post by weekend warrior »
4 studs on my Dec 80, must be a christmas present :D :D
fredguaz
Post by fredguaz »
OK so what changed in 1980? Heater valve? Core pipes? Plenum box? Wasn't the washer tank moved to the cowl area at some point? Wizard what month was your car mfgd?
Fred
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
mdrburchette
Post by mdrburchette »
I know my 71 and 72 have 4.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
today, while i was finishing parting out a 74 spider i discovered that the heater box only had 3 mounting studs. this heater was original and never removed, i took pictures of the mounting attachments. the heater box had never been scratched or had a nut run on it. the cowl panel never had the stud. you can see that there are 3 and not 4. i guess it is an acceptable mistake. as there are usually 4
75 spider
son has 78 spider
