Do i check the oil pump screen?
ORFORD2004
Post by ORFORD2004 »
When i rebuilt the engine, i decided to check the oïl pump screen. Here is what i found ImageImage[/img]
Ithink it was a good idea :shock:
vandor
Re: Do i check the oil pump screen?
Post by vandor »
Can you say bearing failure...
ORFORD2004
Bearing failure bearing failure. Is that the thing that you have to remove the heat treatment from the crank, turn it and do heat treatment again. If so, yes it was a bearing failure 8) The pillow blocks of the crank has to be turn also.
