When I push down on the clutch pedal, I hear a sort of rubbing sound....not loud, but noticeable.
Makes a sheeeaaaaaa sound. When I release the clutch after shifting, noise stops.
Can someone tell me if this is normal, or do I have a problem waiting to happen?
Car is a 81 Spider FI.
Thank You, Marty
Noisy clutch when depressed? 81 Spider
Re: Noisy clutch when depressed? 81 Spider
most likely noise from your throwout bearing. If you have a bad gearshift boot, it can allow tranny and clutch sounds to be audible. The bearing does get louder with age. Normally a pretty slow transition from good to bad.
My new bearing started that transition after less than a thousand miles
- alsgro
Mine is the opposite. Makes some bearing noise when the pedal is up and goes away when I depress the pedal. Been doing that for a couple of years. I think I'm going to take it to Mark soon because I also have a leaky front transmission seal. My money says he does the clutch, seal, bearing in 1 1/2 hrs flat.... F1 style.
That's more likely the gearbox input shaft bearing than the clutch throwout bearing.alsgro wrote:Makes some bearing noise when the pedal is up and goes away when I depress the pedal.
Mick.
- Patron 2019
Yes, as Mick said, or the sleeve where the input shaft protrudes out of the gearbox...mine was slightly dented and caused a rock tumbler sound when pedal was up.131 wrote:That's more likely the gearbox input shaft bearing than the clutch throwout bearing.alsgro wrote:Makes some bearing noise when the pedal is up and goes away when I depress the pedal.
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
