OUCH.
garion
Your car is a: 1979 Fiat 124 Spider
OUCH.
Post by garion »
Saw this go by on reddit...
Link to the converstaion:http://www.reddit.com/r/Justrolledintot ... e_failure/
Re: OUCH.
that's the low compression version
btoran
Re: OUCH.
Post by btoran »
wow. looks like a bit of alchemy going on there.
1975 Fiat 124 Spider
Tobi
Re: OUCH.
Post by Tobi »
So Cal Mark wrote:that's the low compression version
Very low on #2, #3 and #4
tartan18
Re: OUCH.
Post by tartan18 »
This is not a 124 engine. It is a Mk2 aluminum foil compression press made by Ben Guido Enterprises in Urbino Italy. :mrgreen:
Jim MacKenzie
1975 Fiat Spider
fiatfactory
Your car is a: 1970 128
Re: OUCH.
Post by fiatfactory »
garion
Re: OUCH.
Post by garion »
Yeah, that particular forum is a strange combo of professional mechanics, and people who are new to cars. I suppose its a reasonable place to learn stuff, as when someone asks questions, they tend to answer reasonably..
If you notice, they also did get corrected on the fact that its not a SOHC.
If they did tow it, I would wonder how they only damaged 3 of the cylinders. Maybe the timing was off and they towed it?
--John
2007 Audi A4
engineerted
Your car is a: 1974 124 spider
Re: OUCH.
Post by engineerted »
Looks like the cambelt skipped some teeth while running at high RPM.
Something like this when a stone gets cought in the belt at 6000rpm, the small piston pieces blow back up the intake and causes the throttle plates to stick open. Only way to shut it down, in my case was to kill the ingition switch 5secs after it happen. I can imagine that the owner took a little longer to shut it down.
Ted
