Bumperless Treatments?
- Your car is a: 1979 Spider
OK guys: removed the front bumper from our '79 Spider & installed round turn signals in the former bumper shock holes. What, if anything, should I do with the open rectangular holes: leave them open, install NACA ducts, screens, etc.? Thanks much guys!
- toplessexpat
Re: Bumperless Treatments?
On my (long) list of "to dos" is a pair of ram-air intakes. Driver side one to the air box for the carb (or perhaps just with an outlet pointing in that general direction?!) and the passenger side flowing some air over my headers.
I've got a pair of rectangular headlight bowls that have 4" round exits designed to put ram air intakes into some vehicle or other, I forget which, that are slightly larger than our rectangular holes. Some free flow air filter foam with a small piece of black wire mesh across the front, and it should be job done.
Just an idea anyway!
Andy
Andy
bonsaiwino wrote:OK guys: removed the front bumper from our '79 Spider & installed round turn signals in the former bumper shock holes. What, if anything, should I do with the open rectangular holes: leave them open, install NACA ducts, screens, etc.? Thanks much guys!
please post pictures of your new turn signals and where you found them, please!
thank you
i have been hemmin and hawin about what to do in place of the bumper hole for a while
- Your car is a: 1985 Spider
Here is what I have.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- 81SPIDERMATT
These are 2 leds inside and they are very bright. A little small but nobody never said anything (was not arrested)
I also cover a part of the hole for the bumper because the rubber don't cover all the hole.
John
When we did this on Jeff's Coupe the hot air fried the coils... so you need to watch where the air ends up after it goes by the headers.
Likely would be best to be ducted to the carbs from both sides.
- toplessexpat
As ever, wise words Csaba...I'll get thinking again.vandor wrote:>and the passenger side flowing some air over my headers.
John - I'm really liking the clean look. Nice job.
- johndemar
This is what I did. Grittracing (Tony) supplied the lights. I just filled the lines with some fiberglass filler.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
John, the lights look sweet. getting close to that time of year. My first official trip out will be to bring you your spare. Hopefully in a couple of weeks.
- 81SPIDERMATT
- toplessexpat
I tried getting hold of those from Tony, but he's had some fabrication problems and needed new molds. As of a few weeks ago he hadn't got them through.johndemar wrote:This is what I did. Grittracing (Tony) supplied the lights. I just filled the lines with some fiberglass filler.]
Andy
- divace73
Thought I'd add my temporary look, I will one day having the car looking like a pre 74 front end, got all the bits just need the time...one day....
Cheers David
see my >>You tube channel<<
Bumperless look with turn signals that I think look period correct, complete with chrome frames - never understood the 'modern upgrade' look for bumperless turn signals.
