Which plug for which injector
- rjkoop
Is there an easy way to check which plug goes to which injector? I might be able to figure it out based on the wire lengths but the 1st two (closest to the window) aren't obvious. I'm hoping an ohm meter from the distributor and then to the plug connector might work. I'd also like to check that wire connector are good because some of the clips aren't in great shape and the wires have electrical tape near the connector.
Richard
1981 Fiat Spider
Ottawa, Canada
Pictures - https://drive.google.com/drive/folders/ ... sp=sharing
Videos - http://www.youtube.com/playlist?list=PL ... JNKsNVqjfa
1981 Fiat Spider
Ottawa, Canada
- Your car is a: 1975 Spider
Re: Which plug for which injector
honestly it really doesnt matter as the injectors are batch fired, but when you lay ouy the harness it is obvious which plug goes to which injector
son has 78 spider
son has 78 spider
- rjkoop
Yep. Figured that out about 10 minutes ago. Thanks.BEEK wrote:honestly it really doesnt matter as the injectors are batch fired, but when you lay ouy the harness it is obvious which plug goes to which injector
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
