Hole size of Dash Dials
LunaticTaskbar
Post by LunaticTaskbar »
Hi all and a very good morning.
I have a new GPS speedo winging its way from Andytach.com now the item I have ordered is 52mm. I ordered it so I can see the speedo in kph and not the MPH as it currently shows.
Now to my question. As the clock has bad glaucoma, my devious mind is considering the following:
Removing the non working clock. Moving the oil gage to the location of the clock. and mounting the new shiney GPS speedo front and center in the spot previously occupied by the oil gauge.
So before the dash is removed does anyone know the diameter of the holes in question? Will the oil gauge slip direct into the clock location, and will a 52mm add in slide into the location of the Oil pressure?
Any help would be very greatly appreciated.
Have a great day one and all and safe driving. 8)
Ian
Re: Hole size of Dash Dials
Palo Alto Speedometer can fix up the clock perfectly, reasonable price.
baltobernie
Post by baltobernie »
All of the "small" Spider instruments use the same diameter hole, 2-1/16" or 52mm. They're all also mostly the same depth. My only concern would be the depth of your aftermarket gage, and whether or not it will interfere with solid surfaces behind the panel.
You might also want to rethink the position of the oil pressure gage. Fiat put it dead-center for a reason. Our cars don't have a factory fuel or ignition shut-off in the case of oil pressure failure. You're never gonna see that little red warning lamp if you relocate the oil gage down to the corner.
LunaticTaskbar
RRoller123 wrote:Palo Alto Speedometer can fix up the clock perfectly, reasonable price.
Many thanks for the info.
LunaticTaskbar
baltobernie wrote:All of the "small" Spider instruments use the same diameter hole, 2-1/16" or 52mm. They're all also mostly the same depth. My only concern would be the depth of your aftermarket gage, and whether or not it will interfere with solid surfaces behind the panel.
Awesome I will have the guy thats doing it check the depth, its great to learn its 52mm. Thank you.
baltobernie wrote:You might also want to rethink the position of the oil pressure gage. Fiat put it dead-center for a reason. Our cars don't have a factory fuel or ignition shut-off in the case of oil pressure failure. You're never gonna see that little red warning lamp if you relocate the oil gage down to the corner.
Also thanks for the heads up on that one as well I will need to check it more closely.
Thank you.
LunaticTaskbar
I have been reliably informed the new GPS speedometer has been installed. Will post picture when I get home. Not seen it yet...
Ian
LunaticTaskbar
Ok the GPS Speedometer is now in and is working well.
and a couple of the car...
Ian
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
Hey, how did you get my car up there so fast. Just kidding , mine has the flat hood :mrgreen: but looks just like that.
R/
LunaticTaskbar
seabeelt wrote:Hey, how did you get my car up there so fast. Just kidding , mine has the flat hood :mrgreen: but looks just like that.
R/
Just looking at your car in your avitar, does it drive any different with no bumpers on?
I am leaning towards that look. Will need to find a way to illuminate the rear licence plate.
Ian
