I got problems
81SPIDERMATT
Re: I got problems
Post by 81SPIDERMATT »
i know that head shake .... i have seen it more than once... my own head shakes like that from time to time... current project is an old scout.. it gets the head shake as well as the "what kind of truck is that again?" ... part of the fun of driving old unique vehicles .... keep me posted on your repair...
fiat218
Re: I got problems
Post by fiat218 »
Thanks, I will.im not sure what happiining next,my mechanic is having some one look ar it next wed, so we will see what going to happen
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Re: I got problems
Post by fiat218 »
I want to say that it was not the control arms that I bought, I jumped the Conclusion on the make of vicks control arms,
Made a mistake on my part,control arms are not after market,they are Italy source
I just want to apologize on my behalf on jumping the conclusions of things, seems it maybe the shock tower,but that's not a 100 percent sure either,
Live and learn
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
SpecialTool
Re: I got problems
Post by SpecialTool »
I would be concerned about that WAY negative caster angle and check my upper arm installation L to R. Is the car hard to drive in a straight line? Caster should be positive like the specs on your sheet.
fiat218
Re: I got problems
Post by fiat218 »
i did , i belive there are right
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: I got problems
Post by fiat218 »
I ordered new control arms for the 79 ,people think it possible that there a driverside upper on the passenger side, so I just ordered a lower and upper
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
81SPIDERMATT
Re: I got problems
huh ... not smart enough to make a good comment either way .. hope that solves it
fiat218
Re: I got problems
Post by fiat218 »
81SPIDERMATT wrote:huh ... not smart enough to make a good comment either way .. hope that solves it
Lol, it all good, I hope it helps too. I looked back and I only replace the lower on on the passenger side, so hopefully the upper is wrong
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
azruss
Re: I got problems
Post by azruss »
i"m dealing with the same issue. I pulled the suspension off the car, so i could have the a-arms on the wrong side. I dont have any pictures to verify. I have mine so the bulge in the upper a-arm are toward the front of the car. When I go to Vick's, their pix show the same. when I go to Auto Ricambi, they have the bulge going to the back. I looked in my many Fiat manuals and found a couple of pictures with the bulge to the front. So whats right.
fiat218
Re: I got problems
Post by fiat218 »
If I understand your post,and looking at mine,it seems mine sorta curves to the back,but I'm not positive ,I looked at mine last week, I will get the new control arm today I think,I got theses from vicks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
aj81spider
Re: I got problems
Post by aj81spider »
I went out and checked both my cars. Both have the bulge to the front. I've not changed either suspension, they came from different owners and both have been allegedly aligned at different alignment shops.
I'd call Autoricambi - they might just have the wrong picture associated with each arm (easy mistake to make). I'd also trust their opinion over mine any day.
A.J.
2006 Corvette
azruss
Re: I got problems
Post by azruss »
Csaba, what say ye?
azruss
Re: I got problems
Post by azruss »
out of curiosity, I layed out the suspension on my cad program and lowered the suspension 1". that decambered the car by adding .0423" to the bottom a-arm. In otherwords. That adds .28 degrees decamber. my books show a tolerance of .67 degrees.
fiat218
Re: I got problems
Post by fiat218 »
new passenger sideImage
well i have solved my problem, seems to me both driver side and passenger ,the bulge in on the rear side.
new part shows me that it would be in the front, i can see now that the upper need to be swapped around. then the bulge will be facing the front of the car
i think it will align great after this
driver sideImage
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: I got problems
Post by fiat218 »
bobplyler wrote:I just did some checking. From very rough measurements, if you put the left arm on the right side, and right arm on the left side, it will make the caster off by about 11 degrees. (arctan(2/10). On your sheet, it shows this being off about this amount. Also, with this amount of negative caster, it will be very hard to drive (no self-centering). This would also affect the camber.
thanks , i belive this is what happen, needs to be swapped
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
