Never got comfortable with the bullet bike lights hanging off the bumper. found some LED that could fit in the grill. with the OEM flasher, they would flash rapidly and the dash indicator did not work. I found if i hooked them up parallel with incadecent bulb, all was good. tried an LED compatible electronic flasher. it worked fine except the dash indicator didnt work. So i tried hooking up several oem lights and only a light as big as the parking light would make the system work properly. So the solution was to move the bullet light behind the spoiler and wire them parallel with the LEDs. They bullet lights are not visible, but illuminate the ground when on. semi-tricky
Making those brackets was a serious PITA
