http://www.ebay.com/itm/JDM-HONDA-CIVIC ... 0315966971
Are 81 mm ,pistons are pistons,does it matter what they say as to what make of car they are selling it for? Or what
Pistons
Re: Pistons
Not if you know what you are doing.... I have Non Fiat 81mm pistons in a 1438 which is bored and stroked to 1650
R
R
Re: Pistons
What is there to know, I mean what would I have to get
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Pistons
A 16V head!fiat218 wrote:What is there to know, I mean what would I have to get
Re: Pistons
Lol ok.well geeTobi wrote:A 16V head!fiat218 wrote:What is there to know, I mean what would I have to get
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Pistons
Probably the most important thing is 'what are you trying to accomplish'... Some very basic technical info might be pin diameters, dome / crown height, and skirt length. It is certainly much simpler to have a custom piston made than to find a piston which 'may fit'fiat218 wrote:What is there to know...
Ramzi
Re: Pistons
I'm going as far out as a 1608 can be builtRamzi wrote:Probably the most important thing is 'what are you trying to accomplish'... Some very basic technical info might be pin diameters, dome / crown height, and skirt length. It is certainly much simpler to have a custom piston made than to find a piston which 'may fit'fiat218 wrote:What is there to know...
Ramzi
Or maybe I should take the 2.0 out of the 80and use that to the limit,and put the 1608 I have in the 80
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Pistons
[/quote]I'm going as far out as a 1608 can be built....[/quote]
Ahhh yes. Well you know what they say.... 'linear performance is directly proportional to rectangular dollars"
Sounds like a fun build....keep us posted
Ramzi
Ramzi
Re: Pistons
If you are looking to maximize power, then definitely go with the 2.0L That engine is 25% larger than an 1608, and the same mods on it that you plan for the 1608 will produce far more power. Size does matter.
Re: Pistons
Ok thanks, I may take the 2 liter out of my 80
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
