Steering Wheel Removal help?
njoconnor
Post by njoconnor »
So, I've located and read the various threads on removing the steering wheel. I don't have anyone strong/small/foolish enough to yank while I pound (even WITH the nut threaded on!). Off to the local tool store and come back with a wheel/bearing puller. All assembled and cranked down.....see pic:
Using a 1/2 in ratchet, I have the puller as tight as I can go, and still not a bit of budge from the steering wheel (though I have not yet found/tried a cheater). I even was desperate enough to cover the puller's hex end with a socket extension bar, and gave it a few good raps with the ball peen hammer. Nut's there to keep the whole thing from ventilating the garage door.....
Any ideas on what next? I need the wheel out of the way so I can pull the dash and prep the rest of the interior (and hopefully install a new dash this summer). I read about dropping the column, but I have those "round head" bolts and no room to Dremel a slot in the head or grab with a vise grips.
Thanks.....
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
SoFlaFiat
Re: Steering Wheel Removal help?
Post by SoFlaFiat »
Neil, have you tried the PB Blaster, or WD-40?
Soak the splines and walk away, watch a movie, spray some more during intermission. There is no reason except some surface rust that it wouldn't pop off.
Heat is always good too but be careful not to get it too hot.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
this is going to sound real easy.. grab the wheel with 2 hands, push on one side while pulling on the other. fairly forcefully. this will remove the wheel every time, no tools needed
75 spider
son has 78 spider
njoconnor
Post by njoconnor »
Thanks, guys! I'll try both. Got lots of WD-40 (I even have the red straws!). Think I'll sub Top Gear re-runs for the movie.... :) I'll also try the push pull with puller in place.
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
vandor
Post by vandor »
FWIW, if you can't remove it then removing the whole steering column is fairly easy.
azruss
Post by azruss »
rap on the edge of the hub with a hammer while the puller is still on. Sometimes too much force on the puller will tweek the wheel and put it in a bind.
fiat218
Post by fiat218 »
I screw the nut on flush with the shaft,knees under the steering will and one good rap on that nut :) off it comes :D
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
Redline
Post by Redline »
BEEK wrote:this is going to sound real easy.. grab the wheel with 2 hands, push on one side while pulling on the other. fairly forcefully. this will remove the wheel every time, no tools needed
Left-right-left-right always works for me as well.
http://www.124bc.com
profcucchi
Your car is a: 1979 Fiat 2000
Post by profcucchi »
Probably a very late reply, but a fellow Fiat driver told me to:
1. unscrew the nut until it's flush
2. brace my knees under the wheel
3. then take a hammer and nail-driver and hit the center of the nut.
#1 and 2 have been mentioned before, but 3 is a easy method to get it off.
(Sounds very wrong when typed out. :D )
1979 Fiat 2000 "Luigi"
