Rear brake pistons
Rear brake pistons
Changing out the pads/rotors on the rear of my '79 and I need to get the pistons retracted back in - I forget if they both get screwed back in CW or if one is CW and the other is CCW.
Re: Rear brake pistons
Thanks, I finally got it - Had to rig up a tool to screw them in with. The driver's side was tough to screw in but the pass side was a breeze.
- Your car is a: 1975 Spider
then you maybe are going to have a caliper problem, if it goes in hard, then there is a seal issue or a brake hose not letting pressure out, check the temperature of that rotor vs the one on the other side after you drive it a bit,
son has 78 spider
son has 78 spider
Sorry for hacking
But when u install the rear,do u screw them all the way in to slide them over the pads,just so there snug
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
I screw them in as far as they will go.fiat218 wrote:Sorry for hacking
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
