Timing belt life
- rjkoop
Timing belt life
I have to replace the gasket on my camshaft cover and replace my rad hoses. As part of this I was thinking about replacing my timing belt. '81 Spider has 76,000 miles and I don't know the history. But I took off the timing belt cover and the belt looks great.
Is there anyway to determine if it needs replacing? I hate to do all that work when it may have just been done.
Richard
1981 Fiat Spider
Ottawa, Canada
Pictures - https://drive.google.com/drive/folders/ ... sp=sharing
Videos - http://www.youtube.com/playlist?list=PL ... JNKsNVqjfa
1981 Fiat Spider
Ottawa, Canada
Re: Timing belt life
if you dont know the age of the belt...but some cheap insurance....get a new one.
- rjkoop
Yep. I know. Gotta do it!azruss wrote:if you dont know the age of the belt...but some cheap insurance....get a new one.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- Your car is a: 1975 Spider
that belt has some time on it, you can see the teeth pattern on the back side. this is a sign of an old belt, you have to look also at the condition of the teeth, see if they are begining to round or narrow. if it was me and i was unsure of the age, Replace it
son has 78 spider
son has 78 spider
- rjkoop
Now that all the parts are out (including radiator) I think replacing shouldn't be too bad.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
Thanks. I'll do it for sure. Parts are only $88 for everything from Autoricambi.BEEK wrote:that belt has some time on it, you can see the teeth pattern on the back side. this is a sign of an old belt, you have to look also at the condition of the teeth, see if they are begining to round or narrow. if it was me and i was unsure of the age, Replace it
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
To remove the camshaft cover do I just hit the thing with a rubber mallet or do I need to pry it up? Also do I need to remove the distributor? I think it's separate so I think if I remove it in an upwards motion (towards the middle of the engine) I should be ok.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
A rubber mallet works. Even a small ball-peen works if you go very lightly. The dist. can stay in place. If the cover has been on a while, you likely will have to replace the gaskets. Probably a good thing to do to reduce the chance of "oozing" when it is all back together.
- rjkoop
Thanks. I tried the rubber mallet. No luck. Tried a small sledge hammer (lightly). No luck. I was able to get a putty knife to push into the gasket about 1/2". I was thinking about prying that area up with something but I don't want to damage the cover or head surface. Any other neat tricks I can try that are safer?narfire wrote:A rubber mallet works. Even a small ball-peen works if you go very lightly. The dist. can stay in place. If the cover has been on a while, you likely will have to replace the gaskets. Probably a good thing to do to reduce the chance of "oozing" when it is all back together.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Why not tap with a screw driver in between it, gotta come up
Put some effort in it
It just a cover,it not gold
Get a plastic shim
Get a plastic shim
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
The cam covers have 4 little edges (one at each corner) made to put a prybar under them, works every time.
- Your car is a: 1970 Spider
You have already resolved to replace your belt, but I'd just like to add a quick bit of advice. Over the years, I have had two let go. The first one, more than thirty years ago, was entirely my fault and neglect. The second one came apart well before the recommended mileage interval (but beyond the time spec).
My current project is as bad as I have ever seen. (DPO broke the belt, replaced the belt and TRIED TO PULL START the car when the motor was apparently "STUCK!!" Parts and shrapnel went bouncing all over the place!) Who knows how long they dragged the poor thing around while it was digesting itself from the inside out?
If you do not know exactly when the belt was last changed out, replace it.
If you are anywhere near the recommended mileage interval, replace it.
If you are anywhere close to the time interval, replace it.
Max interval is measured in miles and in time. Whichever comes first, replace it. (Can you hear the theme developing?)
A 20 dollar belt (I just bought one for 15 plus shipping.) is heaps cheaper than a grand or more for a replacement engine, and they seem to be getting scarcer and more expensive all the time.
Search around a little bit, you will find pictures of the carnage that is experienced far too often. If you don't find any, pm me, I have a current set - broken valve, head beat all to heck and beyond repair, hole in piston, even a hole in the cylinder wall! I can only imagine the damage down below, bent con rod, bits and shavings of valve, head and piston distributed at random throughout...
Dushore, in Northeast PA
1970 124 Spider (red) and a 1979 2000 Spider (Ferrari yellow)
Also: a pair of 1952 MGTDs
1972 Fiat 850 Spider
1965 Chevelle SS Convertible
1975 Corvette
1986 Lada Niva
1975 Corvette
1986 Lada Niva
- divace73
I've got to agree with BwBrown
Change the tensioner bearing as well....
Cheers David
see my >>You tube channel<<
at the same time, i would also replace the front seals, they are as well accesable at this time, and will save you grief down the road
son has 78 spider
son has 78 spider
From reading his post
Hell you might as well over haul the engine lol
Seems one thing leads to another as in what you should do
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
