Gap Between Dash and Windscreen
- SeldomSeen
- Your car is a: 2018 Fiat 124 Spider
The dash on my '69 spider has a pretty nasty gap between it and the windscreen. Is there a molding that should cover that area?
It's never too late to have a happy childhood - Tom Robbins
1972 Alfa Romeo GTV 2000
1966 MGB Roadster
2007 MINI Cooper S
2018 Fiat 124 Spider Classica
1966 MGB Roadster
2007 MINI Cooper S
Re: Gap Between Dash and Windscreen
there is no molding. you can loosen the dash and push it back to get rid of the gap. There are 2 wing nuts that hold the back of the dash. can get access from the underside. one is located behind the left rear corner of the glove box. some boxes have a cut out so you can get to it. There is a 2nd behind the instrument cluster.
- SeldomSeen
Great! I'll get under there tomorrow and give it a go. Thanks much.azruss wrote:there is no molding. you can loosen the dash and push it back to get rid of the gap. There are 2 wing nuts that hold the back of the dash. can get access from the underside. one is located behind the left rear corner of the glove box. some boxes have a cut out so you can get to it. There is a 2nd behind the instrument cluster.
1966 MGB Roadster
2007 MINI Cooper S
1966 MGB Roadster
2007 MINI Cooper S
If you have problems with that 69 I can fly to colo and drive it to my house
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- SeldomSeen
What are friends for? Sometimes I just don't know what I'm going to do with it but now that top-down weather is here, I might as well have some fun with it.fiat218 wrote:If you have problems with that 69 I can fly to colo and drive it to my house
1966 MGB Roadster
2007 MINI Cooper S
1966 MGB Roadster
2007 MINI Cooper S
