Jeff,again thanks to you and BEEk for the support.The car was really running good.We were able to pass cars coming out of turns and on the straights.That has never happened.We actually need some better tires now,as we are overpowering them and breaking loose around turns.I found out the hard way
I was so carried away with our ability,that I tried an outside pass in a very tight right hander.I got on the rumble strips and went into a lovely drift..er..until it snapped the other way!!! I ended up doing two 360's across the track and into the dirt.I ended up about 50 yards from a flag station,where they all gave me an ovation.
Late in the day Sat.,we started having overheating issues.We tried to rig a coolant recovery system,with a16 lb cap,Sat night.I got to the track early Sun.,and started the car.There was still water coming out,somewhere in the back of the motor.It was dripping at the bellhousing,but I never could see where it originated.We dumped a can of engine stop leak in,to try to get thru the day and it worked.However,there was a metal ''rattling'' noise coming from the motor.I listened with a long screwdriver,but couldnt pinpoint it.Didnt seem to be valves or bearings.We ran until the first driver change.The noise had increased.After much looking we realized the crank pulley nut was gone!!!No spare,nowhere to find one.The keyway and threads were pretty mangled too.But...we went back out with nothing but the belt holding the pulley. As you might figure this lasted for 5 laps.The car came back overheated,with no fan belt and no pulley.At the lunch break I took a golf cart and drove the track looking for the pulley.No luck and we were done.
The car was much improved,but the lack of time on the new motor hurt us badly.When the car arrived,it would barely run but we kept after it.Team Perseverance! The crank nut not being torqued was just one of probably 20 things we found not done correctly.But,we still had a ball.If anyone here ever has a chance to do a Lemons race,do yourself a favor and go for it.The spirit of help and friendship among teams is amazing.Any help,tool,advice,food,or drink you may want or need someone will provide.We were garaged next to the Hillbilly Beemer Boyz again.They had a working tap on the back of their car and 2 gallons of ''lightly carbonated lemon moonshine'' hooked to it!! Needless to say,I had more than my fair share.
So did the organizers,corner workers,judges,and anyone else who walked by.All in all,a fun weekend,although a better finish would have been fantastic
