Big oil leak after my car if off!!!!!!!
majicwrench
Re: Big oil leak after my car if off!!!!!!!
Post by majicwrench »
Spikneck,
If indeed your leak occurs just sitting idling in driveway as you indicated in your PM, it ain't likely your transmission. Oil runs down. Anything above could be creating a leak which will then run down engine/trans and come out below.
Keith
spiknek
Post by spiknek »
well I will be doing this tomorrow and I will up date all of you. and if possible post pictures of my issue! thanks to all great info !!
spiknek
Post by spiknek »
majicwrench wrote:Spikneck,
Keith
idling for a while but alot more after I ride the car and then stop or shut it off?
spiknek
Post by spiknek »
Zippy wrote:Here are a few pictures. The first is where the plug is located. This is a pic I snagged off the net.
The second is a picture of my shift housing. I had to hold the camera above the transmission and take several pictures until I got the aim right. You can see the plug is missing and there is dirt and oil around the opening.
The Hammer
is this freeze plug located to the front or rear of the car ???? am trying to find it but I have no luck!
spiknek
Post by spiknek »
here are some pictures of what i found. the car is up on towers on the front and you all can see that it still leaks from the top!
where you all see my finger right on top of it ??????
Zippy
Your car is a: 1978 Fiat
Post by Zippy »
The plug is part number 5 in the diagram.
It is located on the front of the shift housing on top of the transmission. The opening faces forward.
1978 Spider
spiknek
Post by spiknek »
Guauuuuuuu! thats great so what is the actual size of the plug!? 20mm right
Zippy
Post by Zippy »
I'm just saying this is what I found. There are other possiblities. From your pictures It looks like it is near the back of the right side of your transmission. The first thing I would do is get a rag or paper towels and wipe all the oil off the transmission then take it out for a drive.
Also, hold a camera up there in front of your shift housing and point it at the plug. I took about a dozen pictures before I got one that was good enough to see what was going on. If your plug is in place then you have a different problem.
It is possible the gasket between your shift housing and the transmission is shot.
At first I thought my leak was coming from the speedometer gear since that was where the oil was dripping from.
Good Luck.
Al
1978 Spider
narfire
Post by narfire »
If you are feeling energetic, one can take the lower consol out,and a removable inspection plate is on top of the trans tunnel. Might give you better access to the top. I suppose you could even drive it around the block like that as well.
Chris
spiknek
Post by spiknek »
great tips i will try to take the picts I try putting my hand up in there and it feels very wet!
also the plug I found at NAPA was a 21MM I think I can probably put it in if mine is gone??
manoa matt
Post by manoa matt »
OK its at the back, that's a little different. Just keep digging until you find it. That copper ground strap is non stock, there should be a green one on the drivers side of the engine to the frame rail. Another ground strap never hurts, but on the trans is a new one. Also, what are those two cables running along the bottom, where do they go? Now would be a good time to replace the rear transmission support, it may be sagging and spongy from being oil soaked.
spiknek
Post by spiknek »
yup i agree ! I dont know about those cables but as i dig in i will find out and post it !
spiknek
Post by spiknek »
ok I think I am going to have to remove the trans! If so what all should I remove and in what order!
i can get to it!!!! I removed all the brackets that support the shaft and trans but I still cant get my hand far enough in there to check for the leak. also as I was reaching up in there I felt as if the seal on top of the trans was like coming out to far from the edge and it feels like cardboard??????
spiknek
Post by spiknek »
ok here is where is leaking from (front left side)
manoa matt
That is the speedo cable, there should be a little O-ring in there.
