Hello all,
I am trying to determine the source of a pesky oil leak that's been going on for a while
please see the attached pics
http://tinypic.com/r/oji0x2/6
for whatever stupid reason, the pictures come inverted. sorry about that.
the oil leak seems right above the oil pan, at where the big bolt is...
my question is, what is the purpose of that bolt, and can it be removed and somehow coated to stop the leakage?
any advice is welcome, and again, sorry for the rotated pix.
pesky oil leak
Re: pesky oil leak
I'm kind of confused. That looks like a mechanical fuel pump ?
To the immediate right of mine on the fiat motors is a frost plug opening and then a length of block before the back of the engine.
Re: pesky oil leak
I'm not seeing a big bolt in the pick. I have found that those crazy Italians tried to put all bolts either in a oil passage or water passage. At you next oil change try and remove the bolt a d wrap some Teflon tape around it and screw it back in.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- SLOSpider
Re: pesky oil leak
Looks like your fuel pump gaskets to me. I don't use that RED RTV on the gaskets and would recommend you don't either. Aviation sealer is good if you want to use something or thin layer of formagasket .
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
