I've painted mine yellow.Weelan wrote:Is there a paint that will last on the plastic and right on the heat of the engine? I'd like to go silver with mine like I've seen a lot of people do
I cleaned both sides with brake cleaner and scrubbed well. Wiped down and sprayed with "sandable primer" ,if I noticed any bubbling then wiped down with brake cleaner again.Let it dry and then several coats of Krylon yellow I think. Let it dry well between coats and then a coat of rattle can clear coat. I found on the metal parts I have painted, clear coat on top of the silver the colour went to a kind of peuter colour, don't know what would happen on plastic.
At the moment though, my timing belt is going "commando"
Chris
