Cam pullys swirtched
I am told it is possible to switch the intake and exhaust cam pullys . Does anyone know how to tell the difference by looking at them ie. stamped with a code. They do not indicate left or right. A local fiat mechanic said there is a subtle way to tell but did not tell me how. There are some numbers and letters stamped on the pully but nothing I can understand.
- srwilson
- Your car is a: 1979 124 Fiat Spider 2000
Re: Cam pullys swirtched
Take a look at this thread. There may be some pictures that might help.
http://www.fiatspider.com/f08/viewtopic ... 30#p172435
-Steve
1979 Black Fiat Spider
2006 Black Chevy Silverado Crew Cab
- SLOSpider
Searching always helps Quick answer is with the pullies facing you as they would be on the cams the dowel holes in the 12:00 positions you will see that the intake alignment hole will be just left of the 12:00 position and the exhaust will be just to the right. Also may have STAMPED in the metal S for exhaust and A for intake.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
- divace73
Just to add the S stands for Scarico which is Exhaust in Italian and the A is Aspirazione which is Air intakeSLOSpider wrote: Also may have STAMPED in the metal S for exhaust and A for intake.
Cheers David
see my >>You tube channel<<
