drive shaft seal HELP
brady123
Post by brady123 »
I have a 1981 turbo spider. The rearmost seal between the drive shaft and the tranny leaks fluid. Got a seal kit from IAP. Finally got the drive shaft out. Then a 'C' retainer. Now there's a 1 1/4" nut (?) Won't budge.
rodman
Re: drive shaft seal HELP
Post by rodman »
try impact on it ??
brady123
Post by brady123 »
I wanted advice before impact. Looks like theres something in the way of the nut, or it's connected to the nut. Not sure.
rodman
Post by rodman »
brady123 wrote:I wanted advice before impact. Looks like theres something in the way of the nut, or it's connected to the nut. Not sure.
8444247767_020726907a_b by fiatcs2000, on Flickr
fiatmike124
Post by fiatmike124 »
Sorry I don't know of any special tricks for the nut, but I highly recommend the impact wrench. First there is a spacer that you may/may not need to use a small puller to remove. Behind the spacer is a rubber ring (seal) and a spring. Once these parts are removed, you will probably need the impact wrench for the nut. I believe the nut is torqued to 108 lb-ft. With the nut removed you should be able to remove the yoke and then the seal is accessible. Unfortunately you may need to use a puller on the yoke too. I just rebuilt my transmission but mine was out if the car. Good luck!
Mike
1981 Fiat Spider 2000
2011 BMW 328i Coupe
2001 Mitsubishi Eclipse GT
2003 Yamaha V-Star 650
brady123
Post by brady123 »
I am not THE person under the car, but on line at work (No internet at home) I will ask him. I know he got the rubber 6" 'donut" out (has a retaining ring around it). He was also saying that a socket won't fit in there, an open end wrench won't stay on it. Of course we'd have to borrow a box end 1 1/4" wrench, but he's not sure that would get it. I printed the picture and your suggestion, thanks.
SLOSpider
Post by SLOSpider »
You have to remove the driveshaft centering collar. You can use a tie rod puller or battery terminal puller to get it to slide off the shaft.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
redcars
Post by redcars »
The nut is a 32mm and you need a deep well socket. Just go to an auto parts store and get a deep well impact and you are all set.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
redcars
Post by redcars »
I forgot to add that there is a locking tab that should be bent over on one side of that nut so it needs to be bent back away from the nut.
1970 Fiat Coupe
JerryH
Your car is a: 1976 124
Post by JerryH »
I had a problem with that nut when I rebuilt my tranny. See my post (with photos) here:
http://www.fiatspider.com/f08/viewtopic.php?f=5&t=10260
I finally got it off using a 4 foot breaker bar. My tranny was not in the car so it was possible to use a breaker. If I was under the car I'd try the impact wrench. I'd try a shorter hose with my compressor pressure maxed.
Good luck!
-Jerry
1976 Fiat 124
1972 Fiat 124
brady123
Post by brady123 »
Thanks for the suggestions! The impact worked. Now to put the seal in and put it back together!
