Anyone know anything about their products as in do they work, the theory makes sense from what I remembered from college General Chemistry?????????? Sounds neat.
http://www.counteractrust.com/counterac ... utomobiles
CounterAct anti-rust system at SEMA 2012
- Your car is a: 1982 2000 FI
Re: CounterAct anti-rust system at SEMA 2012
surfingfreeman wrote:Anyone know anything about their products as in do they work, the theory makes sense from what I remembered from college General Chemistry?????????? Sounds neat.
seems logical cause when painting and Grounding the chassis will help reduce the amount of over spray by minimizing the static charges that build up in the paint and the body. Airflow through the hose makes a static charge that is transferred to the body via the paint spray. Subsequent coats are repealed by the static charge induced by the previous coat causing increased over spray as lighter particles do not go the the surface.
When spraying lacquer's the reduced over spray was very evident as was the reduced dusting on the painted surface. It also seemed to polish out quicker. On Enamels the reduction was noticeable, but the main thing was orange peel just didn't happen. My experience.
Thanks Rodman, interesting insights/experiences.
