Tire diameter
5pdrman
Tire diameter
Post by 5pdrman »
I am putting a set of 15" aftermarket wheels on my '78 Spider and want to know the overall diameter of the origianl tire so that I can adjust my tire size to meet the correct wheel/tire diameter and not have a speedometer change. I don't think the tires I have on it now are stock.
Can I change the overall diameter a bit and how much to keep the speedo within 3-5% or is that such a small change in the tire size the it wouldn't make a noticible difference?
Larry
courtenay
Re: Tire diameter
Post by courtenay »
Here's a tire size calculator: http://www.miata.net/garage/tirecalc.html I believe the original for the Spider was 165/85/13.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
narfire
Re: Tire diameter
Post by narfire »
5pdrman wrote:I am putting a set of 15" aftermarket wheels on my '78 Spider
I think most 15 inch wheels will use a 50 series tire. I have 15" with 50 series and when I measured the original 13 inch diameter I was maybe 1/4 inch different? Thought it was around 23 inches???
4uall
Re: Tire diameter
Post by 4uall »
wiggo
Your car is a: 1980 CS0 + 1985 Volumex
Re: Tire diameter
Post by wiggo »
narfire wrote:I think most 15 inch wheels will use a 50 series tire.
Agree. My VX was factory fitted with 195/50x15 on 7x15 wheels.
1980 CS0 FI
1985 VX
