That is too funny
I too had original suspension and shocks last winter
I found this so who knows
On The Ground? Off The Ground?
Next you'll need to decide whether to raise the vehicle for storage or leave it sitting on the ground. Flat spots on the tires used to be the main reason to store a vehicle raised off the ground, but with modern day tires, this has become less of an issue.
Generally, if the car is only parked for the winter, storing it on the ground should be fine. Over-inflating your tires by 5-8 pounds can help prevent flat spotting over the winter.
If you are raising it off the ground, you're next decision is whether or not to remove the wheels. Some people prefer to remove the wheels when storing a car, rather than have them in a high traffic garage area where expensive rims can be damaged.
