Searching for bolts RESOLVED
would anyone know where I could locate these bolts?
Sadly had to drill it out
- manoa matt
Re: Searching for bolts
How many long ones and how many short ones do you need? I should have enough for both sides. If you do buy from McMastercar make sure to get the correct hardness grade. They are susupension bolts and very important.
matt.scarton@gmail.com
Thanks, Tried to find them on their website. Sent them an email...............waiting
Hey Mattmanoa matt wrote:How many long ones and how many short ones do you need? I should have enough for both sides. If you do buy from McMastercar make sure to get the correct hardness grade. They are susupension bolts and very important.
I only need one for now (have not done passenger side yet ) however, if you have all four (X2 for both sides) I would absolutely take them
Just heard back from them
Hi Jay,
We do not sell the type of bolts you are looking for.
Eric
- focodave
Jay,
I don't know if you have "Lowes" up North, but that's where I bought a couple of them for my car.
I bought grade 8 hardware.
I used my bench grinder to modify the heads to match the factory bolts.
Dave
Dave
1970 MGB GT (my other hobby)
Hey Dave,
We certainly do have a majority of the American big box stores up here I never even thought of using my bench grinder interesting. Do you recommend coarse or fine thread?
- focodave
Jay,
Finest thread you can find, and nyloc nuts, if available.
Dave
Dave
Re: Searching for bolts RESOLVED
Okay, so I picked up some Grade 8 nuts & bolts and will grind the heads a little to match them up to what was there. Thanks for all your help, photos to follow
PS if you are in the Ottawa area http://www.ottawafastenersupply.com/
- manoa matt
The original bolts used by Fiat are grade 10.0.
Sooooooooooooooooooooooo does this mean a replacement is in order?
Ground the bolts down
That lower left one looks like mine. The small ring on the splash shield appears intended to keep the heads from turning but it is too light to stop them and it just bends. Same thing happened on mine.
