124 Spider '74 Split Bumpers - pics?
sbbaxter
Post by sbbaxter »
Hello
I want to replace the heavy bumpers from my '78 124 Spider with older thin chrome ones.
I'm looking at some front bumpers on ebay from a 1973 - which appear to be in 3 pieces. Is this normal? Pictures I can find on the internet all look like a single piece front piece.
Does anyone have one of the 3 piece bumpers?
divace73
Re: 124 Spider '74 Split Bumpers - pics?
Post by divace73 »
these split bumper are unique to definatley a 74 model and maybe some late 73's?? Prior to this setup the front was one piece and the rears were 2 and the overiders were metal not rubber.
Cheers David
see my >>You tube channel<<
Fi8spider
Post by Fi8spider »
No I don't think those bars are what you're after.
There are some pics in tdskip's thread showing his 74 with the same type bars you picture.
In the first few posts these specific type of bars were discussed.
http://www.fiatspider.com/f08/viewtopic ... rs#p164416
sbbaxter
Post by sbbaxter »
Thanks All - I think the one piece front is certainly the look I'm after.
Will hold out for some on eBay. Or maybe go with new ones from:
http://www.groupharrington.com/en/part/ ... mpers.html
divace73
Post by divace73 »
sbbaxter wrote:Thanks All - I think the one piece front is certainly the look I'm after.
I've got a set of the harringtons (yet to put on) they are good quality but don't waste your money with their brackets, they are rubbish (at least when I got them)
Cheers David
sbbaxter
Post by sbbaxter »
What's wrong with them?
Bad fit? Bad coating?
I can't see there's much choice without the brackets.
divace73
Post by divace73 »
just poorly cut and poorly bent, I needed to modify mine a lot and they still don't fit right.
Cheers David
azruss
Post by azruss »
i purchased harrington stainless steel bumpers. they are made in vietnam by hand. pounded over mandrel. the front bumpers are not as flat as the stock, but requires a very critical eye to see the issues. the bumper had no twist. the rears were fine. Here is the issue. the brackets on the back of the bumpers are poorly placed and dont line up with anything. I bought the bracket kits and they are substantial but dont match up with car. I spent about 8 hours per bracket getting it right. on the front, i finally cut off the corner tabs and fab'd a new set of middle brackets, mounted them to the car and rewelded them. The rear bumpers will not match the early style license plate lights so you will need to fab something there as well. If you dont have the fab skills you are better off buying a used set of steels and having them rechromed.
sbbaxter
Post by sbbaxter »
Thanks for the info re Harrington.
Will keep looking for a second hand original bumper, maybe one which needs repair and or rechrome
Already have some rears which need welding and rechroming. Anyone know a good rechromer in Seattle or Bellevue?
fiat218
Post by fiat218 »
sbbaxter wrote:Thanks for the info re Harrington.
La plating , there good, I had parts gold plates by them
But there in Los angles
U will be happy
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
