Electric Choke
Electric Choke
Anyone know what to hook up the electric choke to? I would assume that it somehow gets hooked to the temp sensor. Does anyone know where to wire this to? It only has one hook up. Thanks
- Your car is a: 1975 Spider
Re: Electric Choke
hook it to a wire that is hot when the key is in the on position, you can use the wire which went to the idle stop solonoid
son has 78 spider
son has 78 spider
Re: Electric Choke
Thanks Beek. So I just plug that green from the solonoid to the choke. I just might be able to pull that one off.
Re: Electric Choke
is there a trick to adjusting the electric choke? or a starting point for adjusting it?
