Fall/Winter/Spring Projects 2012/13 for Fiona RESOLVED
4uall
Re: Fall/Winter/Spring Projects for Fiona
Post by 4uall »
Did not even need spring compressor.
Followed this video http://www.youtube.com/watch?v=c1akqSJE ... plpp_video & it worked like a charm
4uall
Post by 4uall »
You know that old saying " they don't build things like they used to" well holy crap "they" are correct :shock:
Could not get the nut off to save my life, then it moved but it was just stripped SOB. Let the cutting begin :twisted:
Got 3 out of 4 bolts out arggggggggggggghhhhh :evil:
The control arms on the other hand were in desperate need of replacement.
PininF
Post by PininF »
4uall wrote:@ westy64 I have not tried yet (cleaning/painting the sway bar) however, in retrospect I should have put the bushings on the bar then add the mounts :shock:
hopefully with enough grease/lube they should go on without any issues :wink:
@PininF I have heard of people using storage places. Where are you located? Where do you park/store your car?
Im in Melbourne Australia
Only just got this car, will be moving next year so till then my baby will be in the drive way under a cover for the winter
Will be posting pics of total restoration soon, the roof is already off so is the hole front under carriage for complete replacement. What have we gotten ourselves into :?: Couldn't be happier :D
Cheers
John
4uall
Post by 4uall »
partial success :lol: :( :? broke two Colbalt bits in the process MOTHERTRUCKER :roll:
Now this is the next bolt to tackle :twisted:
unbelievable what you have had to go through with this!
4uall
Post by 4uall »
I have to laugh out loud, because when this is all said & done, I still have the passenger side to do :shock: :shock: :shock:
I wish I
a) had welding tools
b) knew how to weld/torch
C) had easier projects to tackle
:wink:
Might be worth just buying new parts, the A-arms with the ball joints already installed, etc?
narfire
Post by narfire »
Too bad about the lack of welding stuff. Great candidate for the welded nut trick.
Broken stud in the manifold
Place nut over broken stud
Weld stud to nut.
After a bit of cooling, carfully back and forth to loosen nut
Might take a couple of attemps, but does work
4uall
Post by 4uall »
RRoller123 wrote:Might be worth just buying new parts, the A-arms with the ball joints already installed, etc?
Have all new upper and lower control arms for both sides ready and waiting :wink: however, I still needed the brake shield and steering knuckle :?
Looking to have it torched out this week 8)
KidDingo
Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Post by KidDingo »
Hi Jay
Will be tackling the same job next year.
Quick question:
What jack points did you use to keep the car up?
I usually put stands beneath the suspension points, but, obviously, if you pull the suspension apart, the jack points go, too.
_______________________________________________
Michael
4uall
Post by 4uall »
@KidDingo I use the factory jack stand points
The front jack point by itzebtze, on Flickr
When I first started (last year) I did not use the correct places however, quickly put in correct locations and no damage done. Here are some good links :wink:
http://www.fiatspider.com/f08/viewtopic ... ack+stands
http://wwwl.fiatspider.com/f08/viewtopi ... &sk=t&sd=a
No need to say to be very careful pulling and pushing on things when the car is up on the stands...... It is easy to forget. :?
4uall
Post by 4uall »
I also recommend some solid blocks/tires on rims, etc just in case :shock:
4uall
Post by 4uall »
Free at last, free at last Thank God almighty you are free at last 8)
Special thanks to Dave Stoddard http://www.davestoddardautoservice.aaro.ca/ in Ottawa. Took them less than 10min :lol: Told them I would probably be back with the passenger side :lol:
:mrgreen:
