How to remove these bolts RESOLVED
4uall
Re: How to remove these bolts
Post by 4uall »
redcars wrote:Those bent over brackets on the nuts are called locking tabs and are bent over to prevent the nuts from coming loose and ruining you day while you are crusing down the road.
Another lesson learned :shock:
djape1977 wrote:remove the hub from balljoints. hammer out the bolts. no other way to do it, it was intended to be done that way
Thanks, hopefully get this done tomorrow :wink:
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Post by v6spider »
4Uall
Glad you figured it out... Lucky they weren't rusted to the point of cutting. On my spider every bolt has been removed on the steering and replaced because the steering was modified to accommodate my 4.3 l v6. I forgot about the locking tabs as on my spider I used nyloc nuts with new grade 8 bolts. As two of the bolts hold the steering arms make double sure that every thing is torqued proper and tabs are locking the bolts in place. Last you want happening is the steering arms loosening.
Cheers!
Rob
http://www.v6spider.com
4uall
Post by 4uall »
Yesterday came and went. Made a little progress
Zulu
Post by Zulu »
Your front was even dirtier than mine! Looking good so far. If you aren't going to be keeping the big tube bumpers, you can unbolt the bracket mount and get rid of a little bit more clutter. I'm excited to see your final product.
4uall
Re: How to remove these bolts RESOLVED
Post by 4uall »
Done :mrgreen:
