removing front and rear axles-RESOLVED
stello3
Post by stello3 »
I will be dropping the front and rear axles to work on them thoroughly and comfortably (alot of rust). Are there any safety/precautions I should be aware of?
baltobernie
Re: removing front and rear axles
Post by baltobernie »
Fronts are all the same, but rears are different. What year is your car?
stello3
Post by stello3 »
1969 850 spider
is that rust or mud in the photos?
stello3
Post by stello3 »
it is rust
wow, I hope you lots of penetrating oil
stello3
Post by stello3 »
lol!!! I do, + elbow grease and patience
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Post by v6spider »
Wow that is an insane amount of rust.... did the car spend a lot of time on salted roads?
http://www.v6spider.com
stello3
Post by stello3 »
v6spider wrote:Wow that is an insane amount of rust.... did the car spend a lot of time on salted roads?
Nope. that would explain all the rust but, it was parked in 120 degrees (dry) summers for about 5 years. and little to no rain through out the year. it's been out of commission since '94 collecting dust and rust.
stello3
Post by stello3 »
I dropped the rear axle and gearbox today. It was a pain in the @$$. I thought I would do the front and back today but, the back gave me a lot of trouble. the nuts and bolts were easy to loosen. The gearbox mounting brackets were in the way of the A-arm mounting brackets. Lowering the gearbox to move the mounts out of the way caused the A-arm mounts to drop as well and the bolts ended up out of alignment. I was able to punch the bolts out but it took forever due to limited hammer swing space.
stello3
Re: removing front and rear axles-RESOLVED
Post by stello3 »
Front and rear axles are off. Didn't have much trouble removing nuts and bolts. I think the grease and layer of dirt saved them from seizing up. I put penetrating oil on 3 bolts is all. the only difficulty was the rear as stated in earlier post.
4uall
Post by 4uall »
awesome, any pics?
stello3
Post by stello3 »
4uall wrote:awesome, any pics?
here are the pics of the removed axles and transmission
REAR and TRANSMISSION
FRONT
Image Image
Started cleaning the parts
