Can this spring perch be welded or repaired? RESOLVED
4uall
Post by 4uall »
Driving around tonight with our son when the back end started to rattle :? Drove home to find this
PLEASE HELP :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
htchevyii
Re: Can this be welded or repaired?
Post by htchevyii »
It looks like someone cut thru it with a grinding wheel? Sure it can be fixed if you find a good welder as long as the rest isn't so rusty that there's nothing left to weld to.
Trey
4uall
Post by 4uall »
this is what my base looks like, so I am looking to have it all replaced.
4uall
Post by 4uall »
Contacted Csaba and it looks like I am going to get a welder. Would anyone have a spring perch? :?
4uall
Post by 4uall »
Found an antique restoration welder 15 min away that came highly recommended...dropped Fiona off, now we play the waiting game.......... :|
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Post by v6spider »
4uall wrote:this is what my base looks like, so I am looking to have it all replaced.
Smart move there... that perch is rusted all the way through... wow!
http://www.v6spider.com
4uall
Post by 4uall »
Just received this email from the welder "we have brought your car in and taken apart to see visible damage , the only way is to find the piece and replace the whole part as there is many holes and would not be worth to make a small piece , would only last until rest give way, only other option if you cannot find piece is to fabricate one" :shock:
Anyone have that piece? PPPPPLLLLLLLLLEEEEEEEEEAAAAAAAAAAAAAAASSSSSSSSSSSSSSEEEEEEEE :cry:
I thought someone in Quebec had mentioned they had an axle? I really just need the support :shock: ARRRRRGGGGGHHHH :evil:
Exit98
Re: Can this spring perch be welded or repaired?
Post by Exit98 »
Jay,
Keep in mind, this is coming from a non-mechanic.
Swapping out the whole rear is not a tough job. The Fiat book has step by step instructions. I pulled it out by myself in a couple hours.
I did have expert help putting it back together, but really it is quite strightforward.
All you need is a late rear end assembly.
Anyway, good luck.
4uall
Post by 4uall »
I may just have to go that route. He actually has an extensive experince in this field so hopefully I'll be in good hands. :|
With a driven focus on personal service, craftsmanship and professionalism you can rest assured that your vehicle will be in good hands with Ferrante Auto Body. We are a family owned and operated business with over 30 years of experience in auto body repair. Our modern facility is spacious and equipped with the latest in "state of the art" repair systems.
We offer an extensive line of service, specializing in repair, restoration, body work, automotive paint and frame repair.
4uall
Post by 4uall »
Found this, looks like a great solution 8)
http://www.outlawedoffroad.com/showthre ... rch-repair
4uall
Post by 4uall »
Apparently I need some other parts as well :shock: FML!
The garage has discovered that the upper portion is comprimised as well :shock: He said the rear coil (upper portion) sits on a metal seat that slides into a rubber sleeve. Anyone know what these parts could be and where to find them?
4uall
Post by 4uall »
Looks like the garage is going to be able to fabricate everything Fiona needs and she will be back on the road in no time :o
Photos to follow of course. 8)
4uall
Post by 4uall »
Going to pick up Fiona this afternoon with her newly fabricated spring perch :) :D :mrgreen:
Re: Can this spring perch be welded or repaired? RESOLVED
Excellent!
