Can this spring perch be welded or repaired? RESOLVED
Driving around tonight with our son when the back end started to rattle Drove home to find this
PLEASE HELP
PLEASE HELP
Re: Can this be welded or repaired?
It looks like someone cut thru it with a grinding wheel? Sure it can be fixed if you find a good welder as long as the rest isn't so rusty that there's nothing left to weld to.
Trey
this is what my base looks like, so I am looking to have it all replaced.
Contacted Csaba and it looks like I am going to get a welder. Would anyone have a spring perch?
Found an antique restoration welder 15 min away that came highly recommended...dropped Fiona off, now we play the waiting game..........
- v6spider
Smart move there... that perch is rusted all the way through... wow!4uall wrote:this is what my base looks like, so I am looking to have it all replaced.
http://www.v6spider.com
Just received this email from the welder "we have brought your car in and taken apart to see visible damage , the only way is to find the piece and replace the whole part as there is many holes and would not be worth to make a small piece , would only last until rest give way, only other option if you cannot find piece is to fabricate one"
Anyone have that piece? PPPPPLLLLLLLLLEEEEEEEEEAAAAAAAAAAAAAAASSSSSSSSSSSSSSEEEEEEEE
I thought someone in Quebec had mentioned they had an axle? I really just need the support ARRRRRGGGGGHHHH
Re: Can this spring perch be welded or repaired?
Jay,
Keep in mind, this is coming from a non-mechanic.
Swapping out the whole rear is not a tough job. The Fiat book has step by step instructions. I pulled it out by myself in a couple hours.
I did have expert help putting it back together, but really it is quite strightforward.
All you need is a late rear end assembly.
Anyway, good luck.
Anyway, good luck.
I may just have to go that route. He actually has an extensive experince in this field so hopefully I'll be in good hands.
With a driven focus on personal service, craftsmanship and professionalism you can rest assured that your vehicle will be in good hands with Ferrante Auto Body. We are a family owned and operated business with over 30 years of experience in auto body repair. Our modern facility is spacious and equipped with the latest in "state of the art" repair systems.
We offer an extensive line of service, specializing in repair, restoration, body work, automotive paint and frame repair.
Apparently I need some other parts as well FML!
The garage has discovered that the upper portion is comprimised as well He said the rear coil (upper portion) sits on a metal seat that slides into a rubber sleeve. Anyone know what these parts could be and where to find them?
Looks like the garage is going to be able to fabricate everything Fiona needs and she will be back on the road in no time
Photos to follow of course.
Going to pick up Fiona this afternoon with her newly fabricated spring perch
Re: Can this spring perch be welded or repaired? RESOLVED
Excellent!
