Cross member
fiat218
Re: Cross member
Post by fiat218 »
azruss wrote:the window idea is great. looks like you have some stress cracks where the bolts pulled out. you need to weld those up as the stress cracks will continue to migrate. I would make the stud backplate longer than the original. this will move the stress points to an area with good metal.
I WILL DO THAT i have not looked at the frame close, just took a photo
thanks for the advise,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
manoa matt
Re: Cross member
Post by manoa matt »
Why go through all that trouble to recreate the original deficient design of captive bolts? This method is only a bit more work, but much stronger: http://www.fiatspider.com/f08/viewtopic ... =a&start=0
